Beginner & Advanced Tips and Tricks
This months beginner tips reviews the "push and pull" tool that allows you to take a 2D profile and instantly make it 3D. The advanced tip guides you through the use of .stl file to convert a 3D solid and then convert the 3D solid into a 2D vector.
Beginner Tip
PUSH/PULL
The Push and Pull tool is a powerful feature that may just become a key tool in your arsenal. Push/Pull allows you to take a 2D profile and instantly turn it into a 3D object. The tool also gives you the power of quickly creating holes and notches, by simply pushing a profile down through your existing part. In this video you will learn the basics of using the Push/Pull feature.
Watch the video on YouTube
Advanced Tip
STL
The .STL file type or a Stereolithography File is an often-used standard design format for stereolithography, a rapid prototyping technology used for producing 3D parts to be used as a master model for creating numerous prototypes. In this video you will not only see how to use the program to convert an .STL file to a 3D solid, but with the added power of the PowerPack Pro, we will show you how to convert that into a 2D vector.
For more videos, go to our YouTube page. If you have suggestions for other tips, videos, or want to share your creations head over to our Facebook page or email Todd with your questions at [email protected].
