Five editions · one engine
Compare ViaCAD and SharkCAD
Every edition includes everything in the one before it. Find the first column that has what your work needs — that is your edition.
Features ViaCAD 17 2D $129.99Buy ViaCAD 17 2D/3D $279.99Buy ViaCAD 17 Pro $599.99Buy SharkCAD 17 $1,299.99Buy SharkCAD 17 Pro $1,999.99Buy
Performance
64-bit CompatibleEnables handling of large files and complex designs with improved memory management.
2D Drafting & Annotations
26 Dimension TypesIncludes linear, angular, radial, and other dimension tools for precise measurements.
250+ Drafting ToolsComprehensive set of tools for creating, editing, and annotating 2D designs.
2D Dimensional and Geometric ConstraintsMaintains relationships (e.g., parallel, perpendicular) and measurements between objects.
Angular ToleranceEnhanced precision for angular measurements in designs.
Best Fit Line and CircleAutomatically generates optimized lines or circles based on selected points.
Bill of MaterialsGenerates a list of parts/assemblies with quantities and properties.
CutList BOMsSpecialized BOM for woodworking projects, listing cut sizes and materials.
BOM Notes NewUse BOM Notes to attach metadata—such as descriptions, materials, requirements, and URLs—to objects. They also work with Copilot Agents (Copilot Professional Plug-in required).
Conic ToolsCreate conic sections (ellipses, parabolas, hyperbolas) for advanced geometry.
Duplicate Layer CommandReplicates layers (with properties) to streamline workflows.
Precise Model to Sheet - for automatic 2D Drawing GenerationAutomatically generates 2D drawings from 3D models with accurate scaling.
Save Layers with ViewsSaves layer visibility settings alongside specific views for consistency.
Delete Duplicates Supports Polygons NewThe Delete Duplicates tool detects and removes duplicate polygon geometry for cleaner models. PowerPack PowerPack
Advanced Drafting
Auto 3D to 2D (Polylines)Converts 3D polylines to 2D projections for drafting.
Auto 3D to 2D (Precise)High-accuracy conversion of 3D geometry to 2D technical drawings.
CurvesTools for creating and editing Bézier, NURBS, and spline curves.
Section/Detail/Auxiliary ViewsGenerates cross-sectional, detailed, or auxiliary views from 3D models.
File ReferencingLinks external files (e.g., blocks, assemblies) for collaborative workflows.
GD&TAdds Geometric Dimensioning and Tolerancing symbols for manufacturing specs.
Markup and RedlineAnnotate designs with comments, highlights, or revisions.
Simplify Curve ToolSmooths or reduces complexity of curves while preserving shape.
Arc Slot Polygon ToolCreate polygons with arc-based edges for mechanical slots, architectural details, or decorative designs.
AI-Assisted Features
Copilot Help (30-day trial included)Copilot Help delivers AI-driven guidance and CAD insights using Retrieval-Augmented Generation (RAG) for precise, context-aware support.
Copilot ProfessionalCopilot Professional offers AI-driven guidance, CAD data interaction, and text-to-image capabilities, utilizing Retrieval-Augmented Generation (RAG) for precise, context-aware support. Copilot Pro Copilot Pro Copilot Pro Copilot Pro Copilot Pro
Copilot Render NewGenerate conceptual renderings from CAD drawings using natural-language prompts. Customize style, lighting, materials, and design variations for your 2D or 3D models. Copilot Pro Copilot Pro Copilot Pro Copilot Pro Copilot Pro
Copilot Mechanical Parts & CAD Content Library NewIncludes an extensive CAD content library with more than 700,000 mechanical parametric parts, supporting standards such as DIN, KR, ISO, ANSI, and ASME. Copilot Pro Copilot Pro Copilot Pro Copilot Pro Copilot Pro
Part Creator (AI-Powered)AI-powered parametric part generation for gears, screws, and threads with customizable mechanical specifications. Copilot Pro Copilot Pro Copilot Pro
UI & Usability
Modernized User InterfaceThe tool icons use scalable SVG graphics, providing crisp and flexible visuals on high‑resolution displays. The interface also supports separate icon sets for light and dark theme modes.
Support for Dark ThemeFull dark‑theme support, including improved contrast, clearer icons, and polished UI details.
Intelligent Snap CursorAutomatically snaps to geometric points (endpoints, midpoints, etc.) for precision.
Part TreeHierarchical view of design components for easy navigation.
Gripper tool – for transforming objectsDrag-and-drop tool for moving, rotating, or scaling objects.
InspectorPanel for editing object properties (e.g., dimensions, materials).
NavigatorQuick-access panel for layers, views, and design elements.
Customizable Tool PalettesCreate personalized toolbars for frequently used commands.
Customizable GridsAdjust grid spacing, snap settings, and visual styles.
Custom tool palettes in flexible grid layoutsCreate and organize custom tool palettes in flexible grid layouts (e.g., 3×20).
Multilingual SupportSupports English, French, and German interfaces with a multi-language installer for global accessibility.
Video TutorialsBuilt-in tutorials (15+ hours) for learning key workflows. 7 15 15 15 15
3D Connexion Mouse SupportOptimized navigation with 3Dconnexion hardware.
Draw View Type - for easily scaled PrintsPre-configured viewports for scaled printing.
Drawing WizardStep-by-step guide to set up drawings with templates.
Open BackupRecover unsaved or corrupted files from auto-backups.
Print by Layer toolControl printing visibility and settings by layer.
Print WindowPreview and configure print settings (scale, orientation, etc.).
Print Large Plot SizesSupports oversized prints (e.g., architectural blueprints).
Repeat Previous CommandRepeats the last action with a single click.
Save for ReviewExports designs in a lightweight format for stakeholder feedback.
Selection Tools - Lasso, Feature, MeshFlexible selection methods for objects, edges, or mesh elements. Lasso Only
Tool Icon SizingAdjust toolbar icon sizes for readability.
User GuideIn-depth documentation for software features.
Viewport LayoutsOrganize multiple views (e.g., top, front, 3D) in a single workspace.
Architectural Tools
DoorsPre-configured parametric door designs for floor plans.
Make 3DConverts 2D architectural drawings into 3D models.
RoofsTools for designing pitched, flat, or complex roof structures.
SlabsCreates structural slabs with thickness and material properties.
Walls, Multi-WallsBuild parametric walls with layers (e.g., drywall, insulation).
WindowsInsert customizable windows with frames and glazing options.
3D Modeling Tools
ACIS® Solid Modeling KernelRobust engine for precise solid modeling and Boolean operations.
Basic SolidsPrimitives (cubes, cylinders, spheres) for foundational 3D modeling.
Basic SurfacesTools for creating simple surfaces (extrude, revolve, sweep).
Mesh BooleansCombine or subtract mesh objects with Boolean operations.
Move FaceAdjust individual faces of solids or surfaces.
Push/Pull ModelingIntuitive drag-to-edit tool for modifying 3D shapes.
Shelling, BlendingHollow out solids (shelling) or add smooth transitions (blending).
Show/Hide FaceToggle visibility of specific faces on solids/meshes.
Split MeshDivide mesh objects into segments for detailed editing.
Center Line Skin NewCreates a solid by sweeping any cross‑section along a selected centerline.
Weight and Volume TablesCalculate and display physical properties of 3D models.
Sheet Metal Tools (Base,Flange,Contour Flange,Partial Flange,Hem,Rolled Hem,Unbend)Design manufacturable sheet metal parts with Base, Flange, and Unbend tools, including flat pattern exports for fabrication.
Sheet UnfoldFlatten sheet metal designs for manufacturing.
Clash DetectionIdentify interferences between components in assemblies.
Compare PartsAnalyze differences between two versions of a part. PowerPack PowerPack
GearParametric gear generator with tooth profile customization. PowerPack PowerPack
ExplodeDisassemble assemblies or grouped objects into individual parts. PowerPack PowerPack
Advanced 3D Modeling
Add Loop ToolInsert edge loops to refine mesh topology.
Advanced Surface ToolsComplex surfacing (e.g., blends, offsets, fillets).
Bending Along CurveBend sheet metal or surfaces along a defined path.
Boolean Edge TreatmentsSmooth or refine edges after Boolean operations.
Bridge ToolConnect two mesh/surface edges with a seamless transition.
Cover Surface with GuidesCreate surfaces guided by reference curves.
Cylinder SubD PrimitiveSubdivision surface cylinder for organic modeling.
DeformationsWarp or twist objects using lattice or freeform tools.
Draft SurfacesAdd draft angles for mold-making or casting.
Fill HoleClose gaps in meshes or surfaces.
FlangesAdd flanges to sheet metal parts for connections.
G2 Continuous Edge BlendingSmooth curvature-continuous blends for high-end surfaces.
Infinite Plane ObjectsCreate infinite planes for reference or sectioning.
Inset Quad Mesh ModifierAdd inset edges to quad meshes for detailing.
Lofting with GuidesGenerate surfaces between profiles with guide curves.
Magnet ToolAttract and snap objects to custom reference points.
Mesh SymmetryMirror mesh edits across one or more axes.
MicroScribe DigitizerImport physical object scans via MicroScribe hardware.
Pipe Cross Sections NewCreate pipes with various cross-sections that follow a curve path and automatically regenerate when the path is modified.
Pocket Hole for WoodworkingAdd pocket holes for joinery in woodworking projects.
PowerPack Design and 3D Printing ToolsEnhanced tools for 3D printing preparation. PowerPack PowerPack
Quad Mesh ToolsEdit and optimize quad-dominant meshes.
Repair CurvesFix gaps or errors in curves for smoother surfaces.
Rib/Lip FeatureAdd structural ribs or lips to plastic parts.
Skin Surface with GuidesCreate surfaces from multiple guide curves.
Subdivision ToolConvert meshes to smooth subdivision surfaces.
Surface BooleansCombine or subtract surfaces with Boolean operations.
Surface ExtendExtend surfaces to meet adjacent geometry.
Surface AnalysisCheck surface quality (curvature, continuity, etc.).
Surface LoftingGenerate complex surfaces between profiles.
Surface Utilities – including Cut Section, Curved Surface and Explode CurveTools for cutting, curving, or breaking surfaces.
Tangent CoversCreate tangent-continuous surfaces over edges.
Three Face BlendsBlend three adjacent faces seamlessly.
Thumbweight BlendingFine-tune surface blends with control points.
Trim/Join SurfaceTrim or merge surfaces for clean intersections.
Woodworking Joint ToolsPre-configured joints (dovetail, mortise, etc.).
Wrap - Imprint, Emboss, EngraveAdd embossed or engraved details to surfaces.
Rendering, Presentation and Visualization
Data DisplayOverlay design metadata (dimensions, notes) in renders.
Environment MapsAdd realistic backgrounds (e.g., skies, rooms) to scenes.
HDRI SupportUse high-dynamic-range images for advanced lighting.
KeyShot Rendering Live LinkingReal-time updates between ViaCAD/SharkCAD and KeyShot.
Material, Decal LibraryPre-built materials and decals for photorealistic renders.
Wood MaterialsAccess eight additional wood materials in Photo Render Settings to create richer, more realistic rendered scenes.
OpenGL RenderingReal-time viewport rendering with lighting and shadows.
OpenGL Materials/TexturesApply realistic materials in the viewport.
Carbon Fiber Textures NewApply a variety of carbon-fiber textures to create realistic material appearances in your designs.
Photorender Spot LightAdjustable spotlight tool for dramatic lighting effects.
Poster Size File ExportExport high-resolution images for large-format prints.
QuickTime Video RecorderRecord animations or walkthroughs as video files.
Rapid Render Tool for WoodsSimulate wood grain textures and finishes.
Ray Tracing, Shadows, TransparencyHigh-quality rendering with accurate light physics.
Special Lighting EffectsAdd volumetric lighting, glows, or lens flares.
Strip, Dome and Area lightsCustomizable light sources for studio-quality renders.
Studio Backgrounds NewExpanded library of high‑quality studio backgrounds for improved scene presentation.
Animation
Object Time Lines/PathsAnimate objects along predefined paths or timelines.
Panoramic & Object Virtual RealityCreate 360° VR-ready renders for immersive presentations.
Walk Through, FlybyGenerate camera animations for virtual tours.
3D Printing
Auto PositionAutomatically aligns models for optimal 3D printing.
Overhang AnalysisIdentifies areas needing support structures.
Preview SlicesVisualize layer-by-layer 3D print output.
Printer DefinitionsPre-configured settings for popular 3D printers.
Sample STL filesExample files for testing 3D printing workflows.
Show Printer VolumeDisplays 3D printer build volume in the workspace.
Support StructureGenerate removable supports for complex geometries.
Surface Normals CheckVerify surface orientation for watertight models.
Wall ThicknessAnalyze and adjust wall thickness for printability.
Translators
Advanced MCAD Native Translators*Import/export files from SolidWorks, Inventor, etc. (Windows only).
2D PDF ImportImport vector graphics from PDFs for editing.
3D PDF ExportShare interactive 3D models in PDF format.
3MF Import/Export3D Manufacturing Format for 3D printing.
ACIS® R25 KernelCompatibility with ACIS R25 solid modeling files.
Adobe Illustrator™Enhanced import of AI files with layer preservation.
Batch File ConverterConvert multiple files between formats (DWG, DXF, etc.).
Batch Export Single Parts from Multi-Part FilesExport individual parts from assemblies as separate files for manufacturing or collaboration.
BMP ImportImport bitmap images for reference or tracing.
Collada (DAE) ImportImport COLLADA files for game/AR/VR workflows.
DXF/DWG (supports latest Version)Compatibility with latest AutoCAD files.
IGES, STEP, SATIndustry-standard formats for CAD data exchange.
OBJ Import/Export - with Texture supportImport/export OBJ files with UV maps and textures.
Rhino™ 3D ImportImport Rhino 3DM files for compatibility.
SAB ExportExport ACIS solid models in SAB format.
SketchUp Import/Export (supports latest Version)Import latest SketchUp files with automatic glass shader conversion for transparent materials, preserving visual fidelity.
STL Import/ExportStandard format for 3D printing.
SVG Import/ExportScalable Vector Graphics for 2D designs.
XREF ManagementWork more efficiently with XREFs using faster editing, Lightweight mode, and the Attach Folder option for referenced parts.
Other Features
2D/3D Part Library: 25,000Pre-built symbols, parts, and models for quick insertion.
ISO Part LibraryAccess 3D ISO-standard nuts, bolts, and fasteners directly within the Explorer for compliant mechanical assemblies.
Multiple ViewPorts (Draw Views)Display multiple views (e.g., plan, elevation) simultaneously.
Feature lists come from the punch!CAD 17 product-line comparison. The AutoCAD® comparison reflects publicly listed features at the time of the version 17 release; AutoCAD is a registered trademark of Autodesk, Inc.
